Hi! I just recently watched an SVCD that was taken from a DVD. I didn't make it so I don't know what went into making it. Whenever I make SVCDs, they usually are a little blocky (SOME artifacts) and at times the sound can be pitchy. This SVCD I watched had very good audio and crystal clear picture (not blurry or blocky at all). I normally take the vobs off the dvd and then use dvd2avi to frameserve the vobs to tmpgenc to make a CBR or VBR mpeg2 for SVCD but it's always a little blocky. It's not bad, but other peoples SVCDs I've seen are very clear. What other programs should I use instead?
That's pretty much it. One potential program is are you using forcefilm to create a 23.976fps d2v for leaving it at 29.97fps. You'll get a better quaility encode at 23.976fps. What bitrate are you using (2520kbit/s is the SVCD std and near the max for most standalones).
How do I know what bitrate to use? Also, how do I check what the limits are on my standalone player? I have a sony...
<-- DVD Players
just put in your dvd player
Bit rate, as high as possible to make the MPEG 800MB, if you are using 700MB CD-Rs.
Why 800MB
And I suggest using VBR, its longer to encode, but ther results worth it.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Hmm, sounds like your still leaning the ropes. You should first start to lean the basic requirements of SVCD,
https://www.videohelp.com/svcd
Then review the guides on this site, especially using TMPGenc, and get yourself a good bite rate calculator. I've been using this one,
http://www.divx-digest.com/software/avivcdcalc.html
for about two years now without any problems. Haven't had a chance to try FitCD yet.
For a better idea of what your problem is, you should include some info about your settings on TMPGenc; eg, your bite rate used, any filters, are you using the Wizard or manually setting TMPGenc, etc. -
I just Made a svcd it plays good then the problem starts the sound not in sync half way though the movie. I used dvdx to make it into the svcd is there a better programme out there that i could use (user friendly) OR can some one tell me what i can do in dvdx to help me achive a better quailty movie with the sound insync
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 14:40 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 16:05 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
