I fixin' ta get a new dvd writer (sony 510A) and i was wondering which would be best, i've searched the fourm and seen that both brands seems to do the job well. I've bought Apple b/4 and had some good times, but the only reason i bring this up is b/c Fry's seems to only carry the 2X apple discs. I've heard that it 's sometimes possible to burn a 2X at 4X speeds, If the apple discs can do this that what i'm going with.
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press
I would recommend the Fuji discs. To me, they appear to be "sturdier." The manufacturing quality seems better than Apple. Fuji discs feel more "solid" if that makes sense. Although, I do have a box of Apple 4x discs (which I bought from the Fry's here in Vegas).
I have a Sony DRU500AX with firmware 2.0c and it does burn Apple 4x discs at 4x. I don't think you can burn a 2x disc at 4x without changing your firmware. I could be wrong though? I know I'm not touching my firmware because the burner does what is supposed to do. Everyone here says "don't fix what isn't broken" and I agree.
Not trying to patronize you nor insult your intelligence, but cheaper sometimes really means cheaper (as in build quality and longetivity). Saving a few dollars now may cost you more in the long run (unwatchable DVDRs).
*I've used Apple 2x discs and have only been able to burn them at 2x max. Maybe someone is aware of a trick?
Fuji W1 3D Video to Field Sequential 3D DVD
By jonas more in forum Video ConversionReplies: 2Last Post: 28th Mar 2010, 22:50 -
Sale on Fuji blanks
By Seeker47 in forum MediaReplies: 8Last Post: 17th Aug 2009, 15:27 -
HDV to Apple PNG or Apple Motion JPEG A
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 1st Dec 2008, 15:46 -
please cant edit fuji cam avi files
By spikeysonic in forum EditingReplies: 1Last Post: 14th Mar 2008, 09:57 -
Best Buy discontunuing (Japan) Fuji CDRs!
By progrocktv in forum MediaReplies: 14Last Post: 21st May 2007, 07:51
