Hi.....
Could anyone tell me how to put IFO and VOB files onto a DVD.....they are in a folder called TS-video or sometrhing......
It was a DVD film that I copied onto my hard drive..
Any Advise would be great.....
Tomcree
Why don't you start up your DVD burner program in file mode
and tell it to write the VIDEO_TS folder to the DVD writer ? -
If you just copied the files off the DVD onto your hard drive, it probably won't work. That is if the DVD was copy protected. You will need to get the VOB files from a DVD ripping program.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Thanks Guys for your responce...
The files are over 6GB of stuff,,,,so..???
I have a Pioneer 104 dvd -
You must shrink it or split it two dvds because a dvdr only fits around 4.38 GB
dvd to dvd guides:
https://www.videohelp.com/forum/userguides/141024.php
or several other guides
https://www.videohelp.com/dvdripping#30
(just skip the ripping part if you already have ripped the files to your hd)
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
DVD (VOB) files to mpeg2
By maxamillion in forum DVD RippingReplies: 7Last Post: 17th Dec 2008, 23:37 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Want to burn 2 .VOB files to one DVD??
By herbster in forum Authoring (DVD)Replies: 4Last Post: 7th Aug 2007, 22:58
