I used this neat tool called DVTool to join (merge) two mpegs together and it seems to have worked well; however, I also need to convert this new MPEG2 from PAL to NTSC. When I tried to Simple Demultiplex in TMPGEnc, the demux worked only until it reached the "join area" and then ignored the rest of the "joined" MPEG2. I am assuming that TMPGEnc will demultiplex only as long as the headers and whatever are in sequential order but when the header sequencing goes back to zero (0)...it ignores whatever else is there. Hey...I'm a newbie and this is all guesswork on my part...if anyone more knowledgeable can put me right, I would appreciate it. Now what do I do get TMPGEnc to read the entire MPEG2 and demultiplex it? Or do I have to "fix" the new joined MPEG2 before TMPGEnc will read it entirely??? Please HELP!!!
Dan
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Joining MPEGs is always a problem. Don't if you dont have to.
I think I have tried DVTool and it doesn't work. You are
lucky you are starting with PAL. No telecining
I would convert each one separately. That way you can see
if they are ok.
What do you ultimately intend to do with them ? If you want to make a DVD
you never have to join them.
Solar,
It is not a safe guess to think that TMPGenc always joins MPEGs right -
Originally Posted by FOO
Just throwing out ideas is all."A beginning is the time for taking the most delicate care that the balances are correct."
tmpgen works best with MPEG files it creates itself. I've joined many MPEG files and if they were created with TMPGEN, no problems. If they were created with another program, then it's a 50/50 probablility that they will crash out for some reason.
I tried joining two 700 MEG MPEGS once with TMPGEnc and I got royally hosed to say the least. Not only did TMPGEnc not work at all anymore...in spite of reinstalling it, I had to totally reinstall Windows XP as well. For this reason, I have been somewhat hesitant in using TMPGEnc to "join" anything anymore...however, these two mpegs total about 670 MEGS together so I guess I can go back and give TMPGEnc another try. It is a pity that someone has not developed a simple tool that could just rewrite the headers and/or sequencing on MPEGs for problems such as this.
I started out with two 700 MEG AVIs that make up this movie. I determined that after encoding with TMPGEnc, I would have to make three SVCDs to properly fit the movie for viewing on my DVD player. In simple terms this also meant that I would have approx. 66% of the first AVI, 34% of the rest of it...joined with 33% of the beginning of the second AVI and finishing up with the last 67% of the second AVI to make up my three SVCDs. At any rate, this is the best I can come up with...but then again, don't forget I'm a newbie...
Dan
MP4 Joining Problem.
By nicolasonline in forum EditingReplies: 3Last Post: 7th Jun 2010, 14:06 -
problem joining videos
By goatvideo in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2009, 11:19 -
joining problem with v-dub mod
By agent222 in forum Authoring (DVD)Replies: 4Last Post: 2nd Mar 2009, 08:18 -
How to take 'large' home video mpeg2s and burn to DVD?
By tehfreeman in forum Authoring (DVD)Replies: 7Last Post: 19th Dec 2008, 13:24 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
