  1. Hi guys
    I haven't really worked with dts sound before, and therefor I need some advise on how to convert the dts sound to .mv2 or similar so I can multiplex it with my already converted mpeg file!
    Thank's in advance
    koxxxx
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can not convert sound to video (m2v file) ... if you mean convert the dts to wav or ac3 or mpeg audio -- don't....
    convert the ac3 to mpeg audio instead .. basicly because that is your only solution ..
  3. What tools do I need to make a conversion like that?
    Thank's
    koxxxx
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    ac3 to wav or mpeg audio
    besweet + a gui is a good choice ..
    look over to the left .
