    Nov 2002
    sao paulo, brazil
    Is there a place where I can find DTS codecs, to play/encode films in DivX/Xvid?
    LSD
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    powerdvd and windvd have dts decoders ... to make a dts (for dvd) you need an encoder - which are expensive and on up..
    i never have heard of dts on a divx file .. wierd , can be done , but weird .
    you would have to make a wavedts encoded file i suppose to be able to multiplex it with divx/avi ...
    not the same as the dts found on a dvd or in the theater (theater and dvd dts are different also, same as dolby digital in a theater and on a dvd - not the same at all) ..
