Hi,
I was just wondering what sort of quality I would expect if I output S-Video into a DVD Recorder (probably the Philips DVDR70). Would the quality (on max 1hr setting) be as good as normal DVD? What kind of resolutions are the various recording settings?
Just to clarify, Outputing S-Video from my GeForce 4200 card, to the DVDR70, then recording onto a blank disc should work fine shouldn't it?
Thanks in advance
The method that you're talking about is a digital to analog back to digital conversion. Every conversion results in a loss in quality, so no...it will not be as good as a normal DVD. Having said that, you may be satisfied with the results. Try it and see.Originally Posted by ta2
The best method is ripping the DVD to the hard drive of your computer and burning to disk with a DVD writer. If that isn't an option then your method may be your best alternative."Art is making something out of nothing and selling it." - Frank Zappa -
If I was to play a (eg 640x 480) Divx File @ full screen in windows media player, would the quality during the transition go down at all? Or would it be just as good as the original file.
ta2 -
Only as good as your display, but it depends on the source.
What if I took the pin out of a hand grenade and dropped it by my feet, would it blow my legs off above or below the knee? Maybe I'll try it and document the results.
It depends. :POriginally Posted by jdizzy40
Does it bounce? Is the earth soft or hard? Are you wearing boots? How long are your legs? Too many variables."Art is making something out of nothing and selling it." - Frank Zappa
help burning dvds
By bunty90 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 12:53 -
the best burning speed for DVDs
By JohnnyBob in forum Newbie / General discussionsReplies: 13Last Post: 15th Jan 2008, 08:50 -
burning dvds
By terrie29 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2007, 18:08 -
trouble burning DVDs
By nick177th in forum DVD RippingReplies: 9Last Post: 5th Oct 2007, 16:10 -
Burning HD DVDs...Help!
By Anonymous55 in forum Authoring (DVD)Replies: 6Last Post: 14th Jun 2007, 20:37
