I have a problem when trying to capture stuff in Virual Dub on my MSI Starforce 822 Geforce 3 w/tv-in. When trying to grab i get a "Unable to find capturedriver" error, even though i already installed the MSI capture drivers that came with the card. The problem occurs both in XP and W2k.
Any ideas what i can do?
I have a similar problem and a workaround you could try. I have 2 capture drivers installed (ASUS and Mircosoft WDM according to Control Panel>Multimedia>Devices>Video Capture Devices). First I disable (not remove!!) both of them, then run Vdub. It says "no capture devices found". Then I enable just one device and Vdub finds it OK.
Good luck
Vdub: Screen Capture
By dylz in forum Capturing and VCRReplies: 6Last Post: 12th Jan 2011, 17:24 -
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 11:13 -
capture with twain driver
By zalves in forum Capturing and VCRReplies: 4Last Post: 27th Mar 2009, 15:46 -
A tricky Driver for Capture Device Needed
By Digiliz in forum Capturing and VCRReplies: 9Last Post: 8th Jul 2008, 12:26 -
saving driver specific parameters for next capture
By hpishva in forum ProgrammingReplies: 0Last Post: 6th Nov 2007, 14:02
