Closed Thread
  1. Hi, I'm trying to make seamless chapters on VCDs (that's no pauses or stutters or anything when the player switches chapters). It looks like Videopack is about the only thing that will do it but DOES ANYONE KNOW WHERE TO GET IT?
    I've seen a couple links for it posted around here that I've tried that don't work. In fact, every link I've seen anywhere for it lead either to a broken site or a site that doesn't have it. Sounds like even the company that made the damn thing doesn't sell it anymore. Does anyone know where to get this or been to a site recently so they know the link works? Or hell, think you could e-mail it to me?
    Plz help, thanks
    PS Or maybe some other software I could use?
  2. I don't know anything about Videopack, but VCDImager (www.gnu.org/software/vcdimager) can create seamless chapters. You have to be able to write a little xml code though. Search for "vcdimager" on this forum and you will find numerous discussions on seamless chapters for both VCD and SVCD with VCDImager.
    - digvid
  3. Member adam's Avatar
    Sep 2000
    Do not request warez on this site. Enreach makes the product if you want it that bad call or email them, I'm sure they will be happy to direct you to a 3rd party distributor.
    Warez are not hard to find. I just did a google search and literally found i-author within 2 mins, and yes the linked worked.
    If you dont want to pay for a program that does seamless chaptering then use vcdimager otherwise you will just have to find your warez someplace else.
