why are some vid clips size 123mb. but when i play it, only 30 sec. i have to re-encode them.
also have seen vid clips that have sound but looks like the first frame is stuck and shifted.
and lastly is there some how i can get every video and audio codec?[/quote]
Well, you have a few questions so lets tackle them one by one.
differnet companies are making different codecs all the time. Most you will never see, and there are some that are licensed out and you would have to pay for. Also, even if you could have them all, it is not a good idea. Often times the codec drivers would interfere with each other and mess with your computer. The best course of action is to only install the codecs as you need them."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
