  1. hello
    i'm using adobe premiere to edit some videos
    the videos lenght is almost 4 hours.
    i allready have 3 hours on the timeline butnow i can't add more files.. how can i change it to be able to add the last hour of video?
    thanks
    i'm using adobe premiere 6.5
  2. If you want to edit more than 3 hours....get Premiere Pro and edit upto 24 hours.
  3. theres no way to edit more than 3 hours with premiere 6.5?
  4. Nope!! Program limit as far as I know....edit the video seperately and output to disk then join with TMPenc or any other app.....
  5. That's pretty sad that Premiere can't handle more than 3 hours. Switch to Vegas, you can edit a 3 day program together if you want to!
