After posting this thread https://www.videohelp.com/forum/viewtopic.php?t=178324 about the problems I am having with burned PC DVD-Ram discs playing on my E60 (i.e. I want to burn re-writable discs on my pc and test them on my TV before I burn finalized DVD-R's), I found out that the Panasonic HS2 will play DVD-RW discs (even though Panasonics site doesn't mention this). I've also gotten a response that the DMR-E30 won't play DVD-RW.
It would save me much agrivation if I could just go out and buy a DVD-RW burner (instead of trying to figure out this DVD-RAM issue), but I want to be certain it'll be compatible with my player first. Can anyone confirm if the Panasonic DMR-E60 will successfully play DVD-RW's?
According to this website:
http://uk.pricerunner.com/sound-and-vision/vision/dvd-players/164022/details
it can,
good luck,
Jukka -
Well, I finally got hold of a DVD+RW and a DVD-RW to test in the Panny E60. The +RW didn't work, but the -RW did even though the manual says it doesn't support either of the RW's.
Panasonic DMR e60 ep no progressive out
By mammo1789 in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2012, 18:58 -
Panasonic DMR-EH50 and Pan. DVD-RAM disks inconsistent
By rehoboth in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2012, 22:50 -
DVD created with Panasonic DMR EZ 485v doesn't play back on computer
By gray9965 in forum Authoring (DVD)Replies: 2Last Post: 5th Jan 2010, 15:23 -
CRT TV (SDTV) - when i play 16:9 movies and chose Pan n Scan it doesnt wor
By dzsoul in forum DVB / IPTVReplies: 17Last Post: 14th May 2009, 17:28 -
How to confirm the DVD framerate?
By chiappa in forum MacReplies: 5Last Post: 3rd Jan 2008, 05:59
