Hi again;
A lot of folks recommend using a set-top DVD recorded to do the A>D conversion and then just editing and re-burning on computer. I've done similarly when converting a lot of my LPs to CD-R. However, I got the impression that the A>D converter in the standalone CD burner was not as good as a good sound card.
One of the specific issues that someone mentioned (with doing A>D on computer) is the sound synchronization. The Canopus converter I've ordered is supposed to take care of that (Canopus ADVC-100). Should I send it back and just get a set-top DVD recorder instead? Any thoughts?
It seems like, with a little more work, I would get more control over the process by doing it all on the computer, e.g., I could capture to DV and then set the bitrate for MPEG conversion when I'm ready to burn.
Thanks again.
I think you will find the ADVC-100 is one of the best options available for A-D conversion. It doesn't include any software, but I use WINDV or similar to bring the DV into the computer. Of course you need a Firewire card, but almost any will do. I convert the DV with TMPGenc to DVD or SVCD and author it with TMPGenc Author. Cheap and easy with lots of options. The audio always stays in sync and I've never had any dropped frames.
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 13:36 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 23:25 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 11:57 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 18:41 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 13:23
