I'm trying to use forty-two to go from DVD to VCD with my Jackie Brown disc and get the following error message:
sh: -c line 1: unexpected EOF while looking for matching'"
sh: -c line 2 syntax error :unexpected end of file (2)
This is the first time I tried to use this program but it ain't working-any helpful suggestions?
Thanks!![]()
Results 1 to 13 of 13
make sure your file path to save location / source has no spaces, illegal characters etc
My Hardrive is ILLEGAL as far as 42 is concerned
no spaces!!! no " ' / # @ $ etc also.
that should clear it up for ya -
Originally Posted by galactica
so none of my hard drive names can have spaces in 'em?
they all have sorta multi work names...i need to change this?
Thanks -
Okay...so I got it going...it took over a day....and I don't think it worked right....here what I ended up with:
1 file named biles.mp2
another named biles.mpv
and a folder called JACKIE_BROWN-BurnWhatsInHere - except there is nothing in there...
i double clicked on the mp2 and it opened up in itunes and played...
Can i still get a VCD out of these elements?Should'nt I have ended up with BIN and CUE files?
Please hep! -
Originally Posted by ZeroSix
Now, how to author to VCD and what happened to bin and cue files?
Did something go wrong or did I do something wrong?
Am i supposed to end up with them?
What about the empty folder that says "burn this"? -
Actually it worked except...the audio and the video don't seem to be perfectly lined up...This seems to be a recurring problem with me... My other computer is in the shop for a bum logic board but don't know why I'm getting the same type of problems on my iBook...
Another weird problem...my .mpg file now is 1.5 gigs or something...Ain't gonna fit on one CD...can it be salvaged?
I'm sorry- I got a lotta problems with this stuff I guess...[/code] -
Originally Posted by Percy Dovetonsils
Still need to figure out how to split this thing up so it'll fit on 2 cd's--QT Pro won't let me edit 'em.... -
I am having much of the same problems...
Make sure 42 uses separate IN (or use DVD directly), OUT en TEMP folders. Then you wont have to use ffmpeg for muxing.
The out of sync problem is another problem. I found no solution yet.
Give it a try, and maybe we can get closer to 'perfection'.
No output: /bin/sh: -c: line 0: syntax error near unexpected token `('
By marmi in forum ffmpegX general discussionReplies: 4Last Post: 16th Jan 2011, 09:14 -
ffmpegX won't convert files due to "syntax error near unexpected token"
By JayEm in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2010, 17:26 -
Nero Won't see my DVD Burner !!! HEP ME HEP ME!!!
By THE_oldguy in forum DVD & Blu-ray WritersReplies: 14Last Post: 24th Dec 2009, 11:07 -
Installation Error: unexpected EOF while looking for matching `''
By thomashillard in forum ffmpegX general discussionReplies: 4Last Post: 24th Oct 2007, 16:59 -
avi.NET and "Unexpected Error"
By denali in forum DVD RippingReplies: 1Last Post: 12th Oct 2007, 16:01
