Results 1 to 9 of 9
  1. I have Matrix and would like to make a copy out of it to play it in my second DVD player, but it is just imposible. I rip it with smartripper and then using either DVDshrink,InstantCD/DVD, the system just freezes of resets it self. Somebody told me that THE MATRIX is very difficult to copy becuase of the BUNNYoption during the movie. Is that corect and am I wasting my time or is it possible to rip the movie?
    Any ideas/options are welcomes
    Johny
  2. Try DVD Shrink, I backed up the dvd but have not burnt it yet
    I've used DVD Xcopy to create a 2 disk version
  3. [Joking MODE=1]
    Yeah DANGER !!! The Bunny is a very good protection against noobaz ... he can reset your pc ... and rape your sister!!!!
    [Joking MODE=0]
    To make a backup is easy.
    Read the DOOM9's Guides DVD9 to DVD-R.
    That's all folks!
    Rock ON!
  4. well i have made a backup copy of matrix and have had no trouble at all.
    Try using DVD Decrypter in file mode, select all the contents then use DVD shrink as usual and burn.
    give that a go, it mught do the trick.
  5. THAX KAS187,
    I just used DVDencrypter and DVDshrink and the movie is copied without any problem.
    It must have been Smartripper.
    Thx again!
  6. Banned
    May 2003
    Massachusetts
    Umm... if your machine hangs while running IC or DVD Shrink... then there's something wrong with your machine!
    Both of these programs are very well coded - just hit ctrl-alt-del and end the process. No machine hanging!
    Unless... you're... running... WinME or WIn98? Hmm?
    - Gurm
  7. No, it is XP pro.
    But I just did the best way windows works: REINSTALLING FRON ZERO!
    Yep, Windows SUCKS!
  8. I backed up mine, movie only, with smartripper and dvd2one. I picked full backup with smartripper, then choose movie only in dvd2one. and it works perfectly.
    "Terminated!" :firing:
  9. I made a back up with IC7 and use smartripper no problem's.
