  1. i am trying to do vcd to dvd using dvd lab and it keeps saying there is no aspect ratio on some movies, and it cant do them, does anyone know how i can fix this? cos i tried reencoding and it didnt make any difference, any help would be apreciated
  2. what program are you using to encode the video?
    "Hello. My name is Inigo Montoya. You killed my father. Prepare to die."
  3. its ok, they work once burnt, just cant preview them in the program
  4. OK. DVD-Lab will kick the file out if you don't have a correct aspect ratio... it's pretty strict about it. What format did you encode to (Mpeg1? Mpeg2?) What did you use to encode it?
  5. DVD-lab also has a function in the compile DVD area to relax standards. Might want to try that, but realize that if you do this, the finished product may not work on a stand alone player.
