Most conventional VHSs produce a blendind during the playback, the image is never so static as the DVD images.
If i put my VHS tapes in a SVHS, i'm going to get rid of it ? or they will look exactly the same, cause they were recorded with a conventional VHS ?
This thing affects the image in a very hard way, cause i'm encoding interlaced, and the blending image + interlaced images cause a horrible playback.
How can i fix this ?
The SVHS will not help - may make it worse.
Intelacing only looks bad on the computer.
Play it on the TV and see. -
the blending of what i'm talking about, is on the TV , hehehe
but, i solve a part of the problem with a virtual dub filter that i found. , the image look, very static, and the luminace doesn't change to much between one frame and another.
i'm just curious about why i'm still getting a jerky image playing it interlaced on the TV -
Maybe LordVader's seeing the effects of macrovision??? :c*
I don't understand what's meant by "blending" as opposed to interlacing, in the problem description.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
i don't know how to describe the motion problem, my english is not to good.
Most people have to de-interlace VHS captures, because if we put them interlaced on the dvd, they look bad on tv, or jumpy , jerky , blended , or whatever....
i know there's a post where someone put the solution to this, but i can't find it.
is there a method to put interlaced VHS captured on DVD, and get the motion as perfect as the original VHS tape. -
You never de-interlace TV or VHS captures.
and encode interlaced.
That's how it arrives so don't mess with it.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
Howdy,VHS to DVD and I want edit to get rid of the dross and add voice over
By rabbithutch in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2011, 18:12 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36 -
Blending Images(jpg) together
By Soixante in forum EditingReplies: 11Last Post: 24th Jan 2011, 19:28 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 17:27
