  1. Hello,
    I downloaded the trial version of Cinema Craft SP and 2.62 Lite, put the plugin (an renamed to cm.flask) in FlasK. But no matter which version I use of CCE or FlasK all give an error already at starting up of FlasK (at the point it loads all plugins) saying "Cinema Craft Encoder Lite: RegOpenKeyEx: The system cannot find the file specified.(2)" or "CCE SP Trial version: The system cannot find the file specified.(2)"
    What am I doing wrong, how should I get this plugin get to work. I've worked with many plugins, FlasK's and even tried it on several Windows versions upto WinXP all give this same problem.
    Greetz
    Mars-L
    Aug 2001
    Hull
    You first have to install Adobe Premiere 6.0, then you can use the plug-in with flaskMPEG.
    I hope that helped you
    Feb 2001
    Berlin, Germany
    Have you tried the Adobe Premiere Plugin regfix ?
    <font size=-1>[ This Message was edited by: Truman on 2001-10-04 14:24:04 ]</font>
  4. Whooohhhaaa.....
    Damn why didn't I ask this sooner. This solved it.
    I've tried and searched for months to solve it.
    THANK YOU !!!
