Results 1 to 12 of 12
  1. proctor
    Guest
    Hi,
    I have a DivX coded AVI file. I saved it again with VirtualDub and set NO compression under the audio menu. Now I tried to open that new, large avi file with TMPGEnc so I can create a new VCD ... but it won't open it saying: "... can not open, or unsupported.". Why is that ?
  2. not 100% sure what you did - but you need to extract the audio and then put the AVI and the WAV file into TMPGEnc
    follow this
    http://www.vcdhelp.com/virtualdubaudio.htm
    that will get you the WAV file you need
  3. proctor
    Guest
    Because TMP has problems with the compressed audio.
    Use VirtualDub to decompress the audio, save .wav or .avi, as you like. If you save the avi, set video> direct stream copy and audio> full process> PCM uncompressed.
    ^^^ Thats what I did ^^^
    But that didn't work ... I'll know try your link ...
  4. proctor
    Guest
    Well.. with the link you gave me, I get a huge wav file .. but its the same as saving it into a huge avi file that has in it the big wav file... but still... TMP can't and open my AVI file for the video part ...
    Feb 2001
    Berlin, Germany
    Yesterday a audio problem, today a video problem. If you get the message "... can not open, or unsupported.", you have a codec problem or can you play the divx with windows media player? If so, set Direct show multimedia file reader to higher priority (option> enviromental setting> VFAPI plugin). Hope this helps.
  6. proctor
    Guest
    Yea... I'm a problematic person, get to know /me
    btw: you were right (again) and thanks I changed the priority of the "Direct show multimedia file reader" and it loaded the avi
  7. you have to change the plugins priority in tmpeg to open certain divx and avi files
  8. proctor
    Guest
    Thats what Truman said and I allready said that it helped
  9. MAYBE I SHOULD SMOKE ANOTHER!!!
  10. proctor
    Guest
    LMAO !
  11. changing the environment options didnt work for me. do you have any other idea?
  12. yes it did, thanx for your help
