I'm trying to use an ATI AIW128 to capture off of an NTSC cable source. When I capture using VirtualDub, the audio is almost immediately and badly out of synch. Capturing using high bitrate MPEG2 I-frame-only also has audio sync problems to a lesser extent. The oddest part is that capturing from a VCR and a Camcorder didn't cause any problems (using composite or S-video)! Anyone know why capturing through the TV tuner would be different?
Results 1 to 1 of 1
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 02:45 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
audio channels problems, during capture
By popo128 in forum Capturing and VCRReplies: 0Last Post: 5th Aug 2008, 04:25 -
Audio problems with camcorder capture to dvd-r recorder
By illyad in forum Capturing and VCRReplies: 1Last Post: 9th Dec 2007, 07:53 -
How to - Capture DVD 5.1 Audio - Coaxial vs. RCA Audio
By JBredensteiner in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2007, 12:46
