Hi
I did a search but from the subject i really did'nt see a post about it.
Excuse my stupidity about mac's but i have never owned one and know nothing about them![]()
Anyways, what is the easiest way or best freeware program to play vcd's on a Mac powerbook G4 ?
I know how to on a pc with windows media player, ect. but i have a friend who has the above system and called me asking how to play them, i don't even know if it comes with a video player that will play them like windows. or if you can use windvd on a mac ?
Although not freeware, MacVCD is the best software to play VCD's on the Mac. Here's a link: http://www.mireth.com/text/macvcd_sp.html
Visit me at www.virtualaftershock.com/ for all your Custom DVD cover needs. -
ummmm yea.....
DONT USE THAT
instead.... tell your friend.....
VLC (video lan client) www.videolan.org
If you have vcd as cd, put it in the drive, open VLC and go to FILE OPEN DISK. choose VCD and then push OK
then push the play button.
If you have it on the HD in form as .bin/.cue simply drag the .bin to VLC application icon, it will start playing
if you have it as mpeg file, just drag it to VLC.
you get the idea.
By the way, Winblows apps wont run on a mac. This is the best multimedia source player out there.
will play basically anything, even partioned .rar's!
amazing app.
(is out for PC also so you can enjoy it also!)
Enjoy! -
Thats what i like,
FREE
But out of curiosity, isn't there anything that comes with the O.S. that lets you play vcd's ? I never even asked what version she was running for an os ?
But I'll tell her to give it a try.
Thanks Much!!!! -
Originally Posted by CHAOS
Typically VCD is a cdr so to be able to "play" the disk you need an app.
you wont find WINDOWS media player on a mac, for obvious reasons.
So you get Quicktime instead. Yes its a great media player, but there are better.
So a quick download of VLC makes it psuedo-system included and your set to go.
Personally, i prefer the ability to "choose" [not predescribed by microsoft] what I want that works well, and this app is simply amazing. -
Anyway, do get VLC, not later, but now! -
well yea, its for download. Doesnt come preinstalled though
Ripping DVD's to play on mac
By collink in forum MacReplies: 24Last Post: 4th Nov 2010, 07:26 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
OS 9 on my powerbook 1.67
By stanislawski in forum MacReplies: 5Last Post: 22nd May 2009, 03:24 -
Easiest method for Mac (Leopard) DVD backup?
By derrek.mcnab in forum MacReplies: 15Last Post: 12th Mar 2008, 20:30 -
Easiest Way on Mac and PC To Make Audio CD From DVD
By MacPCConsultants in forum DVD RippingReplies: 2Last Post: 26th Feb 2008, 07:18
