How do I convert a .dat file off a vcd to form a dvd file, so I can burn to dvd-r?
Any tool links (as I cant find any) or advice thanx?
Results 1 to 26 of 26
Originally Posted by dabwee
MPEG thus to DVD. Couldn't be more blatent.
And I'll post when I want. I've done it more than a thousand more than you have, so don't even go there. -
Be quite. You are a fat nerd who isn't any help to me.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Why?
Stop replying to my posts "g_shocker182". All I want is help.
The files on a dvd, are they in mpeg format or are dvd files a different format?
I want to know because I burnt a movie and that worked on my dvd player. On another occassion I burnt from a music vcd, convert the .dat files to Mpeg files and created a dvd-r with ULEAD DVD MOVIEFACTORY v 2.0 SE. Why won't the music dvd-r play in my dvd player and my movie dvd-r (Two Towers) does? -
DVDs use vob files, which basically contain MPEG video, subtitles, etc. From an mpeg, you need an authoring program to make the DVD File/Folder Structure for a burning application to burn to a dvdr.
Is this a music cd? What do you mean by Music VCD? -
First thing you need to do is rename the .dat file to .mpg. Then you may be able to use it in an authoring app. Depends on the app.
The music vcd contains a band playing a concert live and there are video clips on it. They are in ".dat" format and the files are called "AQSEQO1 to AQSEQ13".
What program do I use to convert these files to dvd files?
I have Nero Express and Ulead DVD MOVIEFACTORY v2.0 SE. -
dabwee says:
VCD is mpeg1 and DVD is mpeg2. I have heard that some players will accept mpeg1 dvd but I have never tried it.
You want to use your own tools and that's ok but you will have to give a step by step account of your problem if you expect to get help solving it.
In addition some users will not use Ulead products so that may limit some help if the problem is Ulead specific.There's not much to do but then I can't do much anyway. -
All I want is to know how to convert mpeg1 or .dat files to dvd files (VOB files)?
Follow this guide:
https://www.videohelp.com/forum/userguides/141726.php#vcd
Import the created MPEG files into TMPGEnc and join them under "mpeg tools". With that final MPEG, import it into TMPGEnc DVD Author, where you can make chapter points, menus, and finally burn it to DVD. -
Originally Posted by dabwee"Art is making something out of nothing and selling it." - Frank Zappa
The DVD spec includes both MPEG1 at 352x240 1150-1856 and MPEG2 at 352x240, 352x480, 704x480, and 720x480 2.0-10.08 (although the VBR is allowed to dip below 2.0) but not average below it. MPEG2 can also have interlace and 16:9.
The proper way is to extract MPEG data from the DAT using ISOBUSTER.Want my help? Ask here! (not via PM!)
Originally Posted by gll99
Here are the legal DVD NTSC resolutions:
720 x 480 pixels MPEG2
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard
If you have a VCD then do not convert the video to mpeg2, that will only result in a loss of quality. Rip the mpeg to disk, convert the audio, author and burn to disk like in the guide."Art is making something out of nothing and selling it." - Frank Zappa -
So ZippyP, what I have done is converted the .dat files from the vcd and saved them as MPEG1 files on my hard drive. Now how do I convert those to dvd files?
How do I convert the audio from the MPEG1 files to DVD files?
How do I author the MPEG1 into VOB(DVD FILES)? -
My quote:
VCD is mpeg1 and DVD is mpeg2.I am referring to his source videos by comparing the DVD movie whichs he says works and the vcd source which he says does not work. I am aware of the DVD standard but do not make any mpeg1 DVD's it would be pointless. All the vcd I made were from my original DVD movies. I am in the process of recreating those I want on DVD from my original DVD. Thankfully a lot of my vcd's were on cdrw so I can just erase them and resell the blanks to those less fortunate.
This is easier. -
g_shocker182, do I need to join the created mpeg files in tmpgenc or can I leave them as they are?
Also, do I use TMPGENC DVD AUTHOR or can I use ULEAD DVD MOVIEFACTORY SE V2.0 to author? -
Whats the best DVD AUTHORING program thats freeware?
TMPGENC DVD AUTHOR costs to use -
However, according to the guide, InfoEdit does not make 100% compliant disks.
I recommend if you are going to be making DVDs, instead of just VCDs to spend a bit of money and get a good one like TMPGEnc Author or DVD lab. You'll probably grow to like the added functionality."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
How to create video DVD from DAT file
By abhishekm in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2011, 13:28 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
Sony HDR-SR1 and MTS File Conversion to MPEG
By cptspoofy in forum Video ConversionReplies: 8Last Post: 16th May 2011, 12:24 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18
