i have about 7 music videos that im trying o put into one file. i made the timeline in premiere 6.5, but when i go to encode it, it never gets more than 25% done before it crashes. it doesnt matter if i encode in mpg, or divx avi, or dv avi. it crashes every time. if i just try to convert one file it works. but this one file im trying to make akways crashes. anyone know what it could be?
whats rendering? forgive me, im new to premiere, i just got it last week. im used to using cheap software.
I use Premiere a lot but I rarely use it to encode with, especially divx files. You might want to try to encode that one file that is giving you a hard time with another application like Tmpeg. It sounds like something is wrong with it. If you downloaded the file there is a good chance it is corrupted. I think there are some apps that can fix it like divxfix.
Also if you captured these files just try to re-capture the one that is messed up.
Adobe Premiere Pro CS5.5 CUDA encoding slow??
By Brainiac in forum EditingReplies: 5Last Post: 23rd Oct 2011, 00:35 -
Adobe Premiere H.264 Encoding
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 70Last Post: 27th Aug 2009, 03:24 -
Adobe Premiere CS4 + GPU H.264 Encoding
By deadrats in forum ComputerReplies: 1Last Post: 11th Dec 2008, 19:01 -
Encoding for uploading YouTube. Best settings with Adobe Premiere Pro 1.5?
By vid83 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2008, 20:27 -
Adobe Premiere Elements 7 keeps crashing
By NP11073 in forum EditingReplies: 7Last Post: 22nd Oct 2008, 02:23
