I am looking at two different routes. First off, I have a Sony DVD burner and an ATI AIW 8500 128Mb already. What I need to know is which processor would better suit my needs. I will be mainly working with Ulead's Video Studio 7 and Media Studio Pro 7.
I can either go
AMD Athlon XP 3000 (400 FSB)
Gigabyte MB (Dolby 5.1, Dual Channel RAM, 400FSB, 8X AGP)
Corsair TwinX RAM (Probably 512MB to start as it is kind of costly)
OR
Pentium 4 2.8Ghz (533Mhz FSB)
Gigabyte MB with same features as above
Corsair RAM
I really appreciate all the input. I've talked to several people without a really solid answer. Maybe there isn't one.
Im also thinking of upgrading my system. I have heard that the pentium encodes faster, but have no proof. Also you might want to consider a mother board with double the EIDE (RAID) ports so you can have more then 4 drives (Hard discs, DVD, CD...)
If price is not an issue, then I'd go with the Pentium, only because you will benefit from having the faster FSB. Otherwise I've been using AMD chipsets for well over 12 years and really like them. I'm currently running an Athlonxp 1800 in my capture/dvd makin' machine and an Athlonxp 2200 in the web/gamin' machine.
If you do go the Intel route, get the 800FSB Hyperthreading CPU as it's much faster encoding. I built my first Intel after nothing but AMD and could'nt be happier. Encodes are much faster than my XP2400 AMD machine.
I went with a 2.4 800fsb P4 with a gig of Winbond BH-5 ram and it screams. I had it overclocked to 3.2 using the stock cooler. -
Found a pretty solid review on Anandtech. http://www.anandtech.com/cpu/showdoc.html?i=1783
If money is no problem, I would build a dual P4 XEON machine. But that's just me.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 12:09 -
Building a Mini Itx System w/ Lian Li PC-Q7 case
By budz in forum ComputerReplies: 22Last Post: 28th Sep 2009, 03:30 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
One input record other input?
By Davron in forum Capturing and VCRReplies: 1Last Post: 30th Jan 2008, 17:20
