I used to encode movies with TMPGEnc with no problems what so ever then i stoped for few months not my PC keep frezing after few minutes and some time after few hours!!!
My Environment setting is OK, I have all the codec, the AVI contain no errors, I defreged my PC...etc but this did not help...
I viewed all the atricles in here but there was no definite solution.
I'm running win98se, 196 meg, 13 gig, PIII450.
Thank You.
Windows slowly rots. You have to re-install everything every few months.
lmao ... rots .... thats a good one ... (sometimes true - sometimes not)
could also be a slew of other factors - or more than one ...
get a new pc would be a easy solution as a 450 doesnt cut it much in encoding and such ."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I used to reformat and reinstall W98 every three months, then I switched to XP and it's a lot more stable. If you run a lot of programs through your computer, your OS can get corrupted. One other thing to check is your memory. Encoding is very memory intensive and it will show up any memory problems. Download a memory test program and give it a try. If you can afford it, I would replace your computer. It's marginal for encoding video.
Cpu/mb overheat is a very common cause of lockups.
When's the last time you cleaned your cpu fan and heatsink?
Get a cpu/motherboard temperature monitor program and check the temps when you are doing heavy duty processing.
Open the side of your tower and place a regular house fan pointed right at your cpu.
Now run the same process as before and check the temperature again.There's not much to do but then I can't do much anyway. -
Thanks very much to those who replied... I found the problem and I hope this will be of a help to someone else...
I did the mistake of buying a generic pc and it sucks...anyway, I once tried to install win2k server on my machine but it kept crashing until I acceesed CMOS and changed the setting for "Assign IRQ for VGA" to Yes from the default No. I just rememebered this so I changed it to No again and boom I can decode again...
I know that the hardware can play a big part in this but I never thought that this change will cause TMPGEnc to crash or freezes.
Cheers.
Looking around for a solution to this problem.
By chrisyroid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th May 2010, 08:44 -
Help me find the right solution please.
By abeaty in forum Video ConversionReplies: 8Last Post: 7th May 2010, 22:12 -
4:3 and 16:9 on same DVD - solution
By sergem1 in forum Authoring (DVD)Replies: 6Last Post: 15th Jan 2010, 02:03 -
Invisible earpiece solution?
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Dec 2008, 22:36 -
Need Streaming Solution
By jadude in forum Capturing and VCRReplies: 1Last Post: 6th Oct 2007, 18:17
