Results 1 to 12 of 12
  1. Does anyone know if cdcovers.cc is down, or am i the only one that cant access it?
  2. I can't access it either, so it must be down. It does that quite a lot.
  3. Didn't the RIAA shut it down a while back?
    "Terminated!" :firing:
  4. Originally Posted by thayne
    Probably, I've rarely visited it for a while. But it did go down a lot when I did visit.
  5. Yes, I Know Roundabout's Avatar
    Jul 2003
    ...in and around the lake
    They removed all their audio covers a while back due to RIAA pressure, but the last time I checked a couple of weeks or so ago, it was still up and running. Maybe they got shut down by the MPAA?
    Ethernet (n): something used to catch the etherbunny
  6. Member curryman's Avatar
    Jan 2003
    when you say down do you mean homepage is ok but any letter selected results in no display, because if that is what you mean - i have the same problem (pheewww!!) just about to play with my browser settings aswell.
    Apr 2003
    Any luck for anyone? I still can't access the site.
    Apr 2003
    Thanks, Baldrick. I know that their server has been down before. Hopefully, that is the case again.
  9. it was working a few days ago so maybe the servers are down?
  10. It's good to hear that it might be just a server update!!!
  11. It was down a few days then back on now.
    Laurel and Hardy rule!
