I've heard that the current 720 resolution of current DVD writers will within 1-2 years jump to 1080. I know I read that somewhere in this website but since I have America Off Line, it disconnected and I lost the link to the page. I'm interested in passing my Digital tapes and Hi-8 tapes to DVD, but have postponed it waiting for the higher-resolution DVDs to come out. Does anyone have information on this or where I can find out more about this? especially what is the timeframe for them to come out.
Thanks for any info.![]()
Results 1 to 10 of 10
_____________________________
Thank God For Jesus Christ!!! -
What? I'm not sure what you are talking about. Can anyone shed some light on this and cure my stupidity?
You are confusing several different ideas and treads
First the DVDR burner has no affect on resolution. It just transfers data from the PC to the DVDR media. That data can be in many different formats: DVD video, DVD-ROM (ie. pc data), audio, PSX2, Xbox, etc.
Currently the DVD standard calls for 720x480 MPEG2 video at 9.8Mbit/s (see what is DVDR to the left). In the 'near future' HDTV systems will be out and with them HD-DVD. If you look at the supported resolutions for HDTV:
1035i 1920x1035 1125 lines
480i 720x480 525 lines
480p 720x480 525 lines
625p 720x575 625 lines
720p 1280x720 750 lines
1080i 1920x1080 1125 lines (sports)
1080p 1920x1080 1125 lines (cgi)
24p 1920x1080 1125 lines (film)
They are WELL above that of the current DVD standard. But that's a DVD formating issue, the burner has nothing to do with it. -
Originally Posted by Vejita-sama
Due to the limited resolution of Hi-8 you will not gain much capturing at a higher resolution that 352x480 NTSC (352x576 PAL). You could start capturing right away and converting your stuff to DVD without too many worries.
where can I find the description of resolutions for THE DIFFERENT STANDALONE RECORD SPEEDS?
HQ-HSQ-SP- ETC>>> -
If you really want to, you can put HD resolutions on current DVDs. You might have a hard time finding a player that can output the HD signals though. And HD is something like up to 18GB per hour, so you won't get very much on current size DVDs. Time to bring back the 12 inch disks :P
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
billyt,
Regardless of the recording speed for the DVD, the resolutions can be either half D1(352x480) or full D1(720x480). What comes into play is the preference from the user as to what they think looks the best. Generally if you want more than 3 to 3.5 hours on the DVD, then I drop the resolution to half D1, anything shorter than that and I stay at full D1. Some of this also depends on the source material as well. -
Can I use the time base corrector to fix my VCR timer? The resolution of the VHS need to be better than the bitrate of capture. Also, when I encode, I drop frames from the IFO and BUP. How can I fix this? And when I'm done, what software do you recommend I use to burn the DVD+VR in my CD-RW drive?
These weird questions this week are amazing. Simply amazing.
To be serious though, a DVD is the piece of plastic you put stuff on. The resolution is one aspect of the video data you're putting on that plastic disc.Want my help? Ask here! (not via PM!)
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 01:10 -
Higher resolution sizes than 720x480 on MeGUI?
By Umandsf in forum Video ConversionReplies: 2Last Post: 4th Apr 2010, 07:10 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 13:38 -
How to convert DVD to mkv with 720P or higher resolution
By dharmesh13 in forum DVD RippingReplies: 2Last Post: 21st Apr 2009, 19:47 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 01:52
