I'm capturing DV from a video camera using scenalyzer. When I open the AVI file in ACIcodec http://avicodec.duby.info/ it says the codec is a Sony Digital Video or dsvd=Sony Digital Video. But if I look at installed video codecs
-Control Panel
-System
-Hardware
-Device Manager
double click on -Sound, video and game controllers
double click on -Video codecs
click on the "properties" tab
There is no Sony Video codec installed!
What video codec is it?
What video codec should I be using for capture if the end destination will DVD?
Thanks for any insight
hmmmm....so there is no way to tell which codec it is? Does it matter as far as quality goes or is it dependant on source material which codec is better?
If the goal is optimal quality for "home video"...sporting events etc.....would it be better to use MC dv codec or Huffyuv, or other? -
If you are capturing from a DV camera the best codec will be DV, since at capture time you are already using it. This codec is useful for edition, but once you have completed editing your video, it's better to convert the file to DivX or to MPEG.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
Video Codec
By Dave1024 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Apr 2008, 01:46 -
The Best Video Codec?
By Nitro89 in forum DVD RippingReplies: 3Last Post: 26th Feb 2008, 13:58 -
video codec
By ribac in forum Software PlayingReplies: 1Last Post: 8th Feb 2008, 01:09
