Hi,
I use an ATI 8500 DV card with the mmc 8.6 software. If I try to record free tv, the recording stops after about 2 minutes: "The program is copy protected." That is not true. Do you have any idea?
Kind regards
RMC
Results 1 to 16 of 16
Recording a tv program is not illegal. Something is wrong with your computer or software. however I can't help you there. I don't have any ATI products.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
It is true that everything on TV is copyrighted, down to the daily news, and infomercials.
There have to be settings in your Cap program to allow you to ignore.
How you bypass in ATI, if you are using ATI's software, I don't know, but none of the ones I use with 4 other brands has ever shown me that screen. -
I tried to capture the normal tv broadcast program received from the built in tv-tuner of the 8500 DV. The tuner seems to recognize a copy protection that is not there.
Sorry, I forgot my tech specs:
P4 2,4 GHz (no HT)
Intel 845 PE chipset
256 MB GEiL DDR RAM PC 333
Seagate Barracuda IV 80 GB IDE/ 100
Soundblaster 4.1 -
I agree.Originally Posted by gmatov
Here is his website:
www.lordsmurf.com
You can also find him around these forums."A beginning is the time for taking the most delicate care that the balances are correct."
I would think that is the stuff you pick up with the old fashioned lightning rods on top of your house before they had cable & sat.Originally Posted by FOO
Try the AtiMacrovisionDetectionRemoval patch, this solved the problem for me on MMC 8.1 with VHS input, even through a Sima Copymaster.
Fascinating that you get this message on broadcast TV. -
I don't think he is talking about brodcast TV in the sense of antennae.
I think he means the stuff you get for basic cable-basic dish, maybe the non-premium content, no HBO, no PTV.
Still, I don't know why the card would refuse to cap. Should be an ignore button, rather than just quit on him, 2 minutes in.
Cheers,
george -
The new MMC 8.x bails out after 2 minutes with that message whenever it detects Macrovision. I have never had this message on Pay Cable channels, only on VHS. Though since I have applied the patch, if they started MV'ing pay cable I guess I wouldn't know it.
yeah.. doesn't it make you go
boing
about not being able to
capture a pay channel or whatever, w/ a capture card (ATI rant) and yet,
you can record to your hearts content w/ any VCR
Sounds like ATI
is hitching for a ride w/ some butt
'ing to get something in the end.
You know what I'm taling about here
-vhelp -
I'm getting the same thing on my ATI 7500 AIW. Thanks for the links to the hacks.
Once question though, if I use something else to capture the signal, would I avoid having to run the hack at all. I can probably use Virtualdub or Ulead Videostudio to capture.
Thanks. -
It's distortion on the signal tripping off the ultra-sensitive MV DLL in ATI software.
Not the card's fault.
You can either get coax line filters (FM traps, DC blocks, etc) or download the ATI MV hacks. They are on lordsmurf.com in the ATI capture guides.
I'd not dump the ATI MMC. VS is nasty, and Vdub is VFW, not WDM as needed (and no, I don't like the VFW-WDM bridge mods, they aren't real good).
Be sure to get ATI MMC 8.1, 8.5 or 8.7 (only 8.7 if others not an option).Want my help? Ask here! (not via PM!)
Hauppauge PVR-150 (PAL Version) Recording NTSC Source: Impossible?
By darkarn in forum Capturing and VCRReplies: 53Last Post: 16th Aug 2010, 11:06 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
16:9 avi to 16:9 wmv, seems impossible to do?!
By Fking in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2008, 00:27 -
Converting to any format is impossible.
By pownager704 in forum Video ConversionReplies: 3Last Post: 19th Apr 2008, 11:07 -
Impossible to capture stream
By hauk in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2007, 02:12
