Sorry to ask this as I am new and I'm sure there's a "How to" for this question: What exactly ARE the steps to making a disc that will play in a DVD standalone (VCD) and autorun in a CD-ROM or DVD-ROM drive (i.e. Flash or Director exe file)using Nero 5.5.4? Many thanks!!!
<font size=-1>[ This Message was edited by: digitalhecht on 2001-10-04 12:26:41 ]</font>
For burning instructions look ubder the Nero guides to the left under AUTHOR
For autorun instructions, search through the forum as it has been discussed previously. I am not exactly sure on it.
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Thanks. But I couldn't find any instructions for making a disc that has these two functions under the "Author" section. It only tells how to burn pure VCD, SVCD and XVCD. I'm looking to create a VCD with data files (specifically a Flash projector file with an autorun.inf file to launch it). Ideally, the disc (VCD part) will autoplay in a standalone DVD player and the Flash file will autorun in a PC CD-ROM or DVD-ROM drive. In other words, using Nero, do I use the Mixed Mode,CD Extra or CD-ROM Hybrid to start? Thanks.
<font size=-1>[ This Message was edited by: digitalhecht on 2001-10-04 13:22:35 ]</font> -
I figured it out! Very simple: burn the VCD without finalizing, then burn a regular data session with the data files. Thanks anyway!
Sorry, but I doubt very much that "VCD" you create will work if you do this.
If you create your VCDs with Nero, you can actually drag additional files and folders into the ISO filesystem of the VCD in the main screen.
Regards.
Michael Tam
w: Morsels of Evidence -
Right you are, vitualis! Just drag into ISO system and voila! Thanks!
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Data disc
By jayronna in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Oct 2010, 14:53 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
DVD Data Disc
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 05:31 -
DATA DISC instead of AVCHD
By jah711 in forum Blu-ray RippingReplies: 25Last Post: 14th Aug 2009, 18:00
