    Feb 2002
    Luxembourg
    Hi, I have an .avi file which it just over 700mb, can it be burnt to a 700mb CDR by decreasing the size some how? I don't want to make a VCD but just to get it off my HD onto CDR, Thanks
    Zetor
    Mar 2003
    Uranus
    Mode 2 with slight overburn ?
    How bout zip it ?
    How bout recompress it
    get a 800mb CDR
    Feb 2002
    Luxembourg
    I think recompressing it would be the best way for me, what software would I require?
    Zetor
    Apr 2002
    Oskeeweewee Ontario
    VirtualDub.
    Look on the left hand side for the guides..Or, you can simply open up your .AVI in Vdub, cut the beginning and end credits, do a direct stream copy with audio and video. That way you don't have to recompress (thus loosing any quality), and it's fast..
    Good luck!!!!!!!
  5. TMPEnc accepts AVIs.
