Long time reader, first time poster here, so please me gentle...
I have been using VirtualVCR to capture old VHS tapes on a WinXp-AverTV Studio system with great results (due in great part to info in this site, major props and thanx to everybody!). Now I am trying to do the same on a different system, Win2K Pro-Directx 9.0b(installed following ATI's instructions)-ATI AIW 7500. When I capture with MMC 8.5, I get both audio and video, but using VirtualVCR I get audio, but no video (yes, I have tried both checking and unchecking the "smart tee" option in the View tab).
Has anybody had this problem? I looked all over the forums and didn't see anything...
Any suggestions will be greatly appreciated.
EP
The settings with VirtualVCR can be tricky.
Under settings>devices, is the correct input selected?
Also, under settings>tuner>tv tuner device, have you selected the correct country code and broadcast standard? The code for the USA is 1. You also need to update your channels, under the same tab. -
The right input is selected (composite), the right country code is selected. I am starting to think that DirectX 9.0b is the culprit... is there some tool/utility to remove it? I cannot find an uninstall option anywhere...
There's no way to uninstall Directx, when you update. A clean OS install is the only way to get rid of it.
My system is configured similarly to yours and I also had trouble with VirtualVCR, in the past. I'm currently running win2k, sp2, DirectX 8.1, and the last set of ATI drivers before they went with DirectX 9 support. -
Oh, well... I guess I'll have to bite the bullet, backup my stuff and re-install
. Thanks for your help, though...
EP
Little setting problems with VirtualVCR
By Greycat in forum Capturing and VCRReplies: 10Last Post: 28th Jul 2015, 19:07 -
VirtualVCR cap fails in virtualdub...
By Asesinato in forum Capturing and VCRReplies: 36Last Post: 12th Apr 2012, 12:43 -
VirtualVCR Tweaker
By Torrential in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2010, 05:24 -
VirtualVCR help
By LittleJimmy in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2009, 00:34 -
VirtualVCR and ATI TV Wonder
By moorthy in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2007, 19:46
