I made a m2v with cce and avisynth from an avi created with my minidv camcorder. I see that the colors are not right. The bright blues look aqua and the dark blues look black, the yellows look like beige, the pinks look very light and the purple looks gray. The m2v on my computer screen looks ok. I tried using dvdlab with ntsc color safe on and off and still get same result. Is there a way to get the colors back to their original status.
I guess I should clarify that the colors from the dvd on my tv are not correct. The m2v colors on my computer screen look ok.
You are correct. The Safe Color option is only for menus.
I did a movie called Identity over the weekend that came out the same way you are explaining. I have done tons of movies and never had this problem. Even on the same DVD as Identity I had another movie and it did not have this issue. Identity looks fine on my PC but on the TV no. My guess is the DVD was encoded in some different color format like RGB instead of YV12 and that is why it looks so different from others, even though nothing was different for this encode. It is definitely not an issue with DVDLab though.
DVDLab Pro problem, menu background colors change when rendered.
By PSPGamer in forum DVD RippingReplies: 19Last Post: 2nd Mar 2011, 21:42 -
Anyone know why TMPGEnc 4.0 XPress is messing up for me?
By jay_lubb in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 03:53 -
Audio going too fast for FLV, really messing me up :(
By sigpikul in forum ffmpegX general discussionReplies: 3Last Post: 28th Feb 2008, 14:14 -
DVD Decrypter messing up audio
By Cyrus221 in forum Newbie / General discussionsReplies: 4Last Post: 13th Feb 2008, 01:06 -
Where Am I Messing Up?
By aeuzent in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 03:09
