I have a colection of mpeg, avi and asf (some divx some not) that I wish to copy to VCD to play in DVD player.
The question is should I convert them all to DivX first or I can go ahead and burn as is.
Regards
J
DIVX is a type of compression you cannot transfer these to vcd.
You will need to convert to mpg and then burn.
I suggest you read some of the guides in the CONVERT section, maybe use a program called tmpgenc.
If you get stuck post back
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 04:59 -
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 20:35 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 11:25 -
How do you convert HD 720p MKV file to MP4 HD file without losing quality?
By SoccerLover in forum Video ConversionReplies: 18Last Post: 4th Nov 2010, 09:30
