Hi folks, using a Lacie Dvd recorder that i just installed. Its basically
a Pioneer A06 inside.
While burning dvd's i always seem to get this error, with Dvd
Decrypter version 3.1.6.0:
Device Buffer Thread Runtime Exception!
Message=Canvas does not allow drawing
anyone know what this means? The burn continues, and the
resulting discs 'seem' ok, but i dont think this has ever happened
with my old A03 unit.
thanks,
Win
Hey Win!
Did you make sure that your DMA is enabled? Make sure your recorder is set for region 1 as well. Contact me on on trillian after 8:00 eastern. -
thanks guys, but i posted the question in the dvd decrypter forum,
and the creator said the error is NOT a problem. Its something he
has already fixed in the new version, and it doesnt affect my burns.
thanks,
WInston
DVD Decrypter error
By turbochargedRS in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 20:08 -
i/o error in DVD Decrypter
By msdker in forum Newbie / General discussionsReplies: 18Last Post: 20th Dec 2007, 23:03 -
DVD Decrypter error
By tRAVALO in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Aug 2007, 12:10 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error with DVD Decrypter...
By hiimbored in forum DVD RippingReplies: 29Last Post: 4th May 2007, 21:37
