I wasn't sure where to post this request...hope this forum is ok.
I have a d/l a dvdrip of a film in avi format. I have seperated the audio to a .wav file using goldwave then used tmpgenc to create an mpg file from the .wav and .avi files, in which the audio/sync is perfect. Only problem is the video is slightly jerky in places.. I'm sure I've seen somewhere before that if i changed the order of the 'fields' in tmpgenc this could solve my problem
Can anyone enlighten me a little more.
Thanks for your help
Don't ask me, I know nothing - but there's a helluva lotta nothing in this world !!!!
Firstly next time you post do not use the words downloaded and dvd rip in the same sentence as you are breaching the forum rules and it is illegal.
Sounds like it is a problem with your frame rate. Check the frame rate of the original file (in virtual dub) and the frame rate of the template you are using in tmpgenc and make sure they are the same. This will probably fix your problem.
Russ
Jerky picture on DVD
By ANOther1676 in forum RestorationReplies: 1Last Post: 26th Feb 2011, 07:51 -
Jerky picture on Toshiba 32AV615DB/Sony BDP-S370
By togsdragracing in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2011, 17:21 -
Adding subtitles to an SVCD2DVD project :shock:
By bxmbxm in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Aug 2009, 11:54 -
Jerky Picture and Sound on PS3
By det66 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 11th May 2009, 00:11 -
Jerky Picture and sound on PS3
By thumper66 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 5th Mar 2009, 11:51
