Most people avoid using cce's built in audio encoding. For what reason?
Is it just of poorer quality than encoding with BSWEET or are there sync problems etc?
Cheers
I think CCE has its problems when it comes to sample rate conversion. If sample rate of your output file will be the same as input then CCE will do it just fine. At least, that's what i have experienced...but i use BeSweet for audio conversion anyway, since it's recommended by most people here.
Thanks for the reply.
I have tried encoding audio in cce and in bsweet, and to be honest I can't tell the difference. I use sample rate of 48 so there is no conversion, maybe that helps.
CCE Pal to Ntsc conversion-NO AUDIO
By ranosb in forum Video ConversionReplies: 9Last Post: 2nd May 2009, 06:45 -
No audio in AVI2DVD w/CCE SP from MKV file?
By XyBeRz in forum Authoring (DVD)Replies: 2Last Post: 6th Feb 2009, 14:13 -
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 10:10 -
VBR in CCE SP2 creates playback time error leading to no audio
By Albedo in forum Video ConversionReplies: 22Last Post: 11th Jun 2008, 16:23 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13
