I understand that this is unusual, but...
Is it possible to play back a LP/EP VHS cassette on a VCR that can play back only SP and then slow down the speed when recording via a capture card on a PC.
Per what I have read the tape speed is increased for LP/EP. Can I slow it down when converting to mpeg? I also read that a 4 head VCR is required for LP/EP. I think the one I have is a 2 head. May be this will be a problem?
Thanks.
I have no experience in the matter, but it would seem to be plagued with problems. I think you may be better off just buying a cheep VCR player that can play them.
Lets say that you record the playback. It would be in either PAL(at 25fps) or NTSC(at 30fps). In order to adjust the speed, you would need to alter the framerate by dropping or adding duplicate frames. Very similar to transfering between PAL and NTSC.
I suggest you read up on that topic (NTSC / PAL conversion). It could give you some info that is useful."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19 -
S-Video PC to VCR S-Video?? Trying to Convert VHS to DVD
By sandman423 in forum Capturing and VCRReplies: 5Last Post: 29th Nov 2007, 14:36
