i have ntl broadband and i was wondering, when I log off onto the log on screen (i have multiple users), am i still protected from hackers? my firewall only starts up when i log onto a user
It shouldn't be able to let hackers through, because you have not actually selected a user account to work with yet.
Basically, it hasn't actually initiated the windows desktop yet, so the broadband should not be transferring data.
I don't know what will happen if you have one user logged on and then do a swap (leaving the current account logged on, then opening another one without logging off). -
but when I log onto my user, the little network icon in the sys tray says i have been connected longer than I have been logged on.
Sorry then, I don't know. Maybe what you are describing is after you have been working in one account and then switch to another?Originally Posted by cjb1118
If that is what you mean, it stays connected the whole time, but it must use the XP built-in firewall or something, otherwise you probably would have been hacked by now. -
Your DSL/Cable modem is connected at all times, your router is connected at all times, and when you boot your PC, it configures the connection and obtains an IP address lease and is connected as long as it is on.
The account you are logging on to is simply permissions for you yo use your own settings, home page etc.
That's why they call it "always on".
Your firewall is also always on. If you don't have a router with a hardware firewall, you should consider it if even if you have only 1 PC.
Security risks for wireless broadband?
By yogart in forum ComputerReplies: 10Last Post: 16th Feb 2010, 12:49 -
IPS Wireless Broadband security
By yogart in forum ComputerReplies: 0Last Post: 8th Feb 2010, 11:45 -
Changing Broadband From AOL To Sky Help
By Nitro89 in forum Off topicReplies: 0Last Post: 12th Dec 2008, 14:36 -
Mobile broadband USA
By rhegedus in forum ComputerReplies: 14Last Post: 1st Nov 2008, 11:26 -
Comcast to cap monthly consumer broadband starting Oct. 1
By stiltman in forum ComputerReplies: 38Last Post: 31st Aug 2008, 10:07
