So far, I love my new LiteOn 52X CD writer (LTR-52327S with the latest QS09 firmware). With one exception. I can't seem to burn a full or ALMOST full 700 MB CD with Nero 5.5.10.50, the latest version.
I'm using Nero 5.5.10.50 with TDK 48x (CMC; but burns okay at 52x and verifies okay) 700 MB media, making an ISO data CD. I've tried a few other brands of 700 MB CDR's with the same result. Nero tells me there is not enough space. I haven't found the exact size, but it happens as I approach the full CD capacity, even with Nero's overburn enabled and set for 83 minutes.
ISO1 (Mode2/XA) 79:14.32
CD-ROM (ISO) 697 MB (1 660MB AVI file + 3 other files)
356,432 blocks used, CD has 359,996
If I use the Image Recorder, burn the CD to an image on disk and then use Alcohol 120%, it burns the image just fine to the same CD Nero rejected.
Alcohol 120% says:
Session 01:
Track 01: Mode 2 Form 1, Length: 356432(696.2 MB), Address: 000000
Both Alcohol 120% and Nero were set for DAO.
Anyone else having a problem with this?
Thanks,
Mark
In nero, goto File>Preferences>Expert Features> and check the 'enable overburn' feature. Make sure the settings are at 82min 0sec 0frm.
I've used Lite-Ons for a while and they are real work horses. I've had LG, Philips, Samsung, and Sony burners die on me or give me problems, but my Lite-On drives have yet to fail and I'm burning daily- from 4x SVCD, max burn ISO, and the usual CD to CD burns.
Hope this helps -
Thanks for the reply Febre. I've already tried setting the Expert overburn feature several times, and have bumped it as high as 85m 0s 0f with no success.
Mark -
Problem solved. Other forums and news groups have indicated Nero 5.5.10.50 as well as a version of Nero 6 are not handling overburning properly so it's a Nero bug. 697 MB to a 700 MB isn't overburning but must be affected by the bug.
Switching back to an earlier version solved the problem.
Regards,
Mark
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Burn Failure (Nero 7)
By TunkaFrankie in forum DVD & Blu-ray WritersReplies: 26Last Post: 11th Sep 2008, 23:35 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
LiteOn SHW 160P6S won't burn Memorex 8X Dual Layer
By Jackpine in forum DVD & Blu-ray WritersReplies: 7Last Post: 20th Jan 2008, 16:49 -
NO sound when i try to burn in nero 7..
By lil_jayz76 in forum AudioReplies: 3Last Post: 3rd Nov 2007, 21:05
