If I have a picture which software can I use to put text on fir example a company name?
I am using frontpage for my web. Then when I click on the picture and hit edit it take me to paint. Is there a better program to edit pictures then paint?
Results 1 to 12 of 12
Hi guys thanks. I just saw how to edit text with photoshop. One more questions. Can you change the color becuase the only settings it has is font and size?
Also after I save my template as a psd how do I covert it into a web template to edit the buttons on frontpage? When in photoshop I click save for web the color on the pic gets distoreted. -
you just asked a mouthful. it depends on what version you have on the text color question. to save a template, you have to create slices then save for the web. again, the act of saving will depend on what version you have.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
http://www.photoshopcafe.com/ has a great tutorial on how to go from photoshop to webpage. it uses dreamweaver but i think you should be able to adapt it for your use.
I prefer dreamweaver over front page because it lets you do more things and is not very difficult to use.
I'm with Devanshu - if you're having trouble placing text over a graphic or may - at any time - want to change that text, use a layer to lay text over the image.
Dreamweaver's great for that and you can tweak it in notepad, if necessary.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I always prefered Notepad over Dreamweaver or any of those other "Do it for you" programs
Too true. But I do use Dreamweaver to plunk in complicated tables. :c) Much, much quicker for stuff like that. Once they're in, it's Notepad from there on.
I tried to learn pure HTML code, but never got around to learning it all the way.
:c) Well, it's not something I'd want to learn if I didn't have to use it all the time, but I do.
It can be tricky. Accidentally delete one little "<" or something, and hours of work goes wonky! :cD
But if you need to design all the time, the WYSIWYG progs are more like WYSIKCTWYGBNE
"What You See Is Kinda Close to What You Get, But Not Exactly!"
:cDThere's no place like 127.0.0.1
How many are using laptops for your design computers?
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 30th Apr 2012, 13:49 -
Web design software.
By Moonstomp in forum ComputerReplies: 6Last Post: 2nd Jul 2008, 14:26 -
Web page design software/Need advise
By alegator in forum ComputerReplies: 22Last Post: 20th Mar 2008, 13:19 -
Would you design your own hardware if you could?
By yoda313 in forum PollsReplies: 5Last Post: 25th Jun 2007, 21:35
