  1. not quite for dvdr but thought u guys might be able to help. Im looking to edit a MIDI file. its 5 mins long i want first say 45 seconds (for phone ringtone) anyone know any software that could do it? i googled it and nothing much really came up. any help would be apprechiated.
    thanks
    chad
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    do you want to make an audio track out of it and edit that, or do you want to keep it in midi and edit it?
    if you use a midi sequencer, you'll be able to edit the file. you can find freeware ones at www.audiomelody.com
    just find the spot where you want the file to end, and delete everything after...
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. how do i
    "delete everything after"
    chad
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    it's going to depend on your sequencer, but most seqencers will show a grid, running left to right (from start to end), with blocks on that grid representing your instruments.
    let's say you only wanted the first 8 bars of the music. you would go to bar 9, select everything from bar 9 to the end of the track, and delete it.
    what sequencing program are you using?
    - housepig
    Housepig Records
    out now:
