Results 1 to 12 of 12
  1. Unknown_Killer
    Guest
    I got a problem with SVCD2DVD+!!! I can't update it on Windows XP. It gave an error like it can't debugg it or something. Someone can help me please?
    Thx Matt
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    fancy screenshotting your error?
  3. Unknown_Killer
    Guest
  4. Unknown_Killer
    Guest
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Email me & I'll send you a diagnostic build.
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    if you redownload the installer i think this has been fixed.
    Jul 2002
    Scotland
    Could someone advise the steps todo a screenshot.
    thanks.
    dlb.
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    1. ctrl + alt + printscreen captures the current (active) window in to the clipboard.
    2. Paste it to your favourite graphics package or paint (in accessories).
    3. Save it and do whatever with it.
  9. Unknown_Killer
    Guest
    I've redownloaded the installer. Re-installed and the update give the same error!
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    CAn you email me to resolve this?
  11. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok - due to radio silience - i going to make a guess. Are you installing the msi file, then downloading the update and running the update?
    Installation
    1. Download the installer
    2. Unzip & run the Windows Installer package.
    3. Run the demo. You will be sent to a URL to download the updated version: SVCD2DVDDEMO.zip
    4. Unzip the exe file, from this zip, over the old exe in the directory where you installed the demo.
    5. Run & enjoy.
    make sure you are doing #4 -> extract the exe from the update zip and REPLACE the old exe in the SVCD2DVD folder. Then run the program from the start menu.
    Am i close or should i get my coat?
    CB
  12. Unknown_Killer
    Guest
    Thx it works!!!
