Hi,
I am trying to capture from VHS on a Pentium III 450, 256MB ram, ASUS TNT-3400 vga, Sound Blaster Live Value, 45GB IBM ATA/100 drive, using VirtualDub and Avi_io with PicVideo codec. Picture is good, no lip sync problem but there's extra noise in the audio. It sounds like an old LP record is playing. VirtualDub produces a lot of noise. Avi_io does a much beter job but still has some noise. Anyone has any suggestion on how to get rid of the noise.
Many thanks in advance.
Results 1 to 1 of 1
extra subtitle from avi sub
By vominhquoc in forum SubtitleReplies: 3Last Post: 16th Feb 2014, 15:08 -
noise over audio file
By mlrs1996 in forum AudioReplies: 7Last Post: 9th May 2011, 13:28 -
Can you burn a CD-extra using .cue file?
By piano632 in forum AudioReplies: 3Last Post: 15th Feb 2009, 21:45 -
WMV file has 'extra text' at end of it & PS3 won't play...
By fatguy in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2008, 11:40 -
Remove extra audio tracks from a xvid avi
By beatnikbandit in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2008, 09:34
