I have a movie with 5 scene selections ie chapters. After playing a scene (chapter) on the dvd it automatically continues on to the next chapter. Is there any way to make it go back to the scene selection screen instead of playing the next chapter. If not I believe the only way would be to divide the movie into five separate movies.
Thanks,
Jim
I believe you are correct in that you'd have to split them into seperate titles/movies.
W -
Just confirming what you've already heard, seperate clips, connect end of movie to menu.
In DVD lab where you actually select the chapters you can set the start/end of the file.
So I think you could created 4 empty movies (if this is how many you want)load each one with the same title and set the the movie length parameter. eg start 4.13 finish 10.20 using the preview window ...that way you don't have to split the files or re-encode anything you are just creating 4 titles from the one fileHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149
missing chapters on standalone dvd - dvdlab
By lukasz.w80 in forum Authoring (DVD)Replies: 0Last Post: 10th May 2011, 10:56 -
how to rearrange the movies in dvdlab
By sumeshkri in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2010, 07:18 -
Authoring with DVDLAB 1.3 and chapters get out the farther I go!
By gwoiler in forum Authoring (VCD/SVCD)Replies: 5Last Post: 28th Feb 2010, 18:18 -
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 19:04 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 05:55
