Results 1 to 16 of 16
  1. Hi
    I am new to DVD burning and am experiencing a few problems. When i copy DVDs using DVD shrink.
    The video quality of the copy is good and it plays without a problem until it gets to the last quarter of the movie. It is then that the picture and sound freeze. the DVD drive reads the DVD for several seconds and then the movie continues. It gets worse as you go towards the end of the movie. This not just one off, i have tried several DVDs.
    Could someone please help.
    Many thanks
    Jazz
  2. Sounds like you are using cheap media .... has all the classic signs.
    Try a good Ritek disk.
    May 2003
    could be bad media ...... many players have the problem you describe when cheap media is used .... particulally princo media, what disks are you using
  4. Hi
    I am using disks that came with the writer and a few White Label ones.
    Is Ritek DVD-R, if not which are good DVD-R brands.
    thanks
  5. One way to check is to play the VIDEO_TS folder on your HD prior to burning to DVDR. In my own hands there's nothing wrong with Princo media (do a forum search) but others disagree. Ritek is popular and very vew people seem to have problems. Ritek makes DVD-R (and other) media:
    http://www.allmediaoutlet.com
  6. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    Always check the DVD before you burn it, will save many coasters.
    RitekG04 media are top of the line, in my opinion.
    And it sounds like you have a bad media issue.
  7. Banned
    May 2003
    Massachusetts
    Everyone sing with me...
    BAAAAAD MEDIA!
    BAAAAAAD MEDIA!
    BAD MEDIA! BAD MEDIAA! BAD MEEEEEDDDIIIIAAAA!
    - Gurm
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    BAAAAAD MEDIA!
    BAAAAAAD MEDIA!
  9. THANK YOU FOR THE MUSIC.....
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  10. I think you have one of two problems.
    Look closely at your disk, does it have were marks from a bad drive/player?
    I recently burn a original content disk and took it to a party. All the people at the party were in the movie and that was the first time it was ever played. It had the same type of problem you are having. Thought great I picked a great time to burn a coaster. It locked at the end of the disk totally with about 5 mnute maye 15 to go in the movie!
    Ok Latter I looked at the disk, it had wear spots from rubbing in my friends playstation. Grrr, one play ate my disk before it was even fished playng the first time!
    Or othe more likely problem,
    Baaddd Mediieee i ooo aa
    Bad medie eioo
    Bad media
    EI EI OWE
    Sorry, but they did it twooo////
    And no if they jumped off a bridge I would jump to, agian!
    overloaded_ide
    Spambot FOOD
    Anti-Spam
  11. i'm not so sure that the problem is bad media (but i'm not saying it isn't !! ).
    The think is (i have a toshiba drive and i use nero ) and some time i have the same problem , but i use verbatin media (and it's supose to be a god media, right ?!? ), also many time's when i make a copy of a movie and the a week later i try to make another copy of the disc (that i've recorded before) , when i try to copy the dvd-r to the harddrive almost every time the windows gives a error message and i'm unable to copy the disc and there for i can't duplicate it
    Does someone help me ?!?
    I think the problem might be from the burning software !!! does anyone agrees ?!?
    .... and in my opinion the same applies to the problem of "jazzjazz
  12. Banned
    May 2003
    Massachusetts
    Bad media, bad drive, bad software...
    But if it locks up near the end after playing most of the movie fine... it's bad media.
    BAAAD MEDIA!
    BAAAAD MEDIA!
    - Gurm
  13. Member northcat_8's Avatar
    Mar 2003
    Go to www.shop4tech.com order you a 25 or 50 spindle of the RitekG04 discs. The 25 spindle is $54 including tax and shipping. That makes your cost per disc $2.16, now I don't know what you pay for the verbadum or whatever you use. But no matter what the price, reliablity and dependability for $2.16 each will be cheaper than 3 coasters, and headaches and still not having a DVD that will play right.
    It can't be your burn process unless your DVD was too big for the disc and the burner couldn't close it, but your burning software won't let you do that usually. Also if it were your burn process you would notice it throughout the disc not just at the end. Sooooooooo.....me-me-me...
    BAAAD MEDIA
    BAAAD MEDIA
    I SAY IT IS BAAAD MEDIA
    MEDIA NO GOOD
    NOT USING WHAT YOU SHOULD
    IT IS - BAAAAD MEDIA.
    USE RITEKG04
    THEY ARE GOOD.
  14. k, thanks for advising me
    But, what i would like to know is if everybody here (in this topic) can copy the full movie (recorded earlier in a blank dvd) into the hard disk without any kind of problems (error and stuff ).
    P.s. I use winMe and i use the aspi drivers from the Os instalation.
    Do you think that i should instal new aspi drivers ?!?
    P.s.- I've just use ImgTool burn , and i have to say that the dvd-r seem a lot more "stable".....
  15. Member northcat_8's Avatar
    Mar 2003
    Yes.
    WinME was a decent OS, I would suggest upgrading to XP Pro.
    Mar 2002
    Manchester, UK
    If you've got Nero, there's a utility called CD Speed that effectively tests the quality of the DVD. A nice, smooth, climbing curve means that your DVD drive on your PC can read the disk well.
    "Jitters" on the graph mean the drive has struggled to get high-speed reads.
    Yellow vertical bars mean recovered errors were encountered and red bars are unrecoverable errors.
    Check the disks you burn on your DVD-ROM instead of your burned.
    Riteks seem to be considered to be the best budget DVDRs. Verbs are good premium DVDRs and if you want top-notch, try the Pioneer ones at £5.00 each!
    You can also do something similar with DVD Info Pro which is free (for the version with a the odd ad or pretty inexpensive for the ad-free version).
