I am trying to back-up Two Weeks Notice and so far have created 5 coaster and given up.
I have used several combinations of software including AnyDVD, DVDSHRINK, CLONEDVD and others.
Can anyone please advise what I am doing wrong, I have a Pioneer 106 and have tried JVC and Traxdata media.
Thanks in advance,
Kernal
Results 1 to 11 of 11
Turn your computer on.
Actually, try giving us at least 1 detail as to how you made the coasters. Maybe then someone could help -
Thanks, turned my computer on but I am still having problems.
Thought the fact that I had stated which software, drive and media I was using may have been enough.
The writer just stops unexpectedly this can happen at any point the best I have managed to get to is about 90% complete but generally only get to 1 or 2 %, I normally have to re-boot my PC to get the coaster out of the drive, the system does not lock up it just won't let me open the drive.
Using the following system.
AMD Athlon 1.2 Ghz
512MB RAM
60 Gb (2 x 30Gb IBM in RAID 0 format)
Kernal -
Usually burning programs will have a "test" or "simulate" option. When selected it will not actually write to the disk, but prented that it is. That way if something is amiss, you find out before burning a coaster. Try enabling this option. It may give you a message about the problem instead of just freezing. Either way, its worth trying out, it won't cost you any money for a wasted disk.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Thanks, will try that.
Was wondering if anyone else had managed to back this DVD up OK ?
Kernal -
I backed it up without any problems. Maybe try downloading and run one time ForceASPI re-boot and see if that helps. Also before you burn try shuting down any running aplications like virus, popup blockers, and firewalls.Originally Posted by Kernal
Oh and to avoid wasting any more DVDR media use a DVDRW disc until you get the problem sorted out.
If you are just having trouble with this DVD but have succesfully backed up others the DVD probably needs a good cleaning or resurfacing (DVD doctor). I have had several DVD's that played fine but when I went to copy they would give me trouble. DVD Doctor (or is it Doctor DVD?) fixed it every time.
Presto,
something I am curious about, sometimes cleaning a disk is recomended before ripping when the problem is a burning failure!
If the rip did not seem to have problems/errors, and was writen to the Hard drive, then why would a burn fail once it starts? Do the burning programs actually check the video files durring the burn, or just burn whats on the hard drive?
I mean I can see a burn failing if it can't read the hard drive, but once the file is saved I would think it would be burned to the disk however it is writen on the Hard drive.
I am sure someday I will have such a problem is why I am asking! -
Yes I did.Originally Posted by KernalPinnacle Studio 8 and DV home video editing (ver.9 already home)
How long is your video collection? Days, weeks, months years, decades?
By yoda313 in forum Off topicReplies: 12Last Post: 1st Jan 2012, 08:10 -
Netflix problem anyone notice this?
By canadateck in forum Video Streaming DownloadingReplies: 6Last Post: 8th Oct 2011, 15:50 -
ripping dvds hell...it's been going on for weeks
By bubbleboy in forum MacReplies: 2Last Post: 14th Oct 2008, 15:48 -
LITE-ON lasted a couple of weeks... What to buy now?
By smackypete in forum DVD & Blu-ray WritersReplies: 13Last Post: 11th Jul 2008, 20:19 -
Giving a 2 weeks notice
By DVinci in forum Off topicReplies: 3Last Post: 7th Sep 2007, 01:13
