Can someone advise what I am doing wrong I have just installed avisynth following instructions tried to test in media player and I get this error message "invalid or corrupt data was encountered"
What do you want to do? If you don't mind, post the script here.
Also... did the message pop up from media player, or wat the error message on the media player video window with red on black text?
If you get the popup then you do not have it installed right, or you forgot to turn off extesion hiding and are feeding MP a text file. You can find out by going to a command prompt and doing a directory listing. If the file says ksdjfls.avs you are ok of it says slkdjfs.avs.txt then you have a problem.
New AVISynth UI
By tin2tin in forum Latest Video NewsReplies: 23Last Post: 19th Jan 2012, 01:53 -
avisynth
By sportflyer in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2010, 04:36 -
Using avisynth
By bsuska in forum Video ConversionReplies: 8Last Post: 16th Jul 2009, 08:32 -
AVIsynth help!
By helper in forum Newbie / General discussionsReplies: 11Last Post: 15th Oct 2008, 03:35 -
Avisynth 3.0
By nbi in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:50
