can these files be burnt on to disk to view in a dvd player![]()
They can if they're a (S)VCD bin image.Originally Posted by reg1786
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
yes if they are (s)vcd images nero will burn bin/cue images provided you have a version higher than 5.5 just select the cue file to burn by selecting burn image from the file dropdown.
personally though i prefer cdrwin for burning cue/bin files as it is most likely that cdrwin was used to create the cue/bin files a demo version is available here http://www.goldenhawk.com/ -
open nero
go to file->burn image
choice view all file types from the bottem, load the .cue file
will open a burn screen sure u know what to do from there...
if you get a message saying burning dont support TOA i think it is, then the cue sheet is trying to give wrong burn instructions
so go to file->burn image again
select view all files
this time load the bin file, select data mode 2 from the drop down and click ok
this will now open a burn screen from where u can carry on...From The End To The Start It Begins In The Middle -
We knew they could be burnedOriginally Posted by Baldrick
We just didnt know if they would play.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
