hello all,
I have been using my write for few weeks and successfully burnt some dvd-rs, but have no luck at all with dvd+r (memorex and verbatim). The firmware of the driver is 1.05. Do I need to upgrade to 1.06? Anyone has this problem? Thanks for all the help.![]()
One of my friends uses 1.06 FW and says the drives 'plus' performance is excellent.
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
i have the 106d for a week now and so far i could burn at 4x... using tdk dvd+r and memorex dvd+r (office depot sale). very good burner.
flashed to 1.06, tried one more dvd+r, still no go...am i the only one having this problem?? thx for help
All I burn is DVD+R with my Pioneer A06. Seems that if you are burning the -r format the same way you burn the +r format you shouldnt be having troubles.
First thing I would do is make sure it is def. the Pioneer A06/106.
Pull the drive out if you have to and look at the model/serial number.
I'm sure it is the right model but crazier things have happend. Did you get it from a reliable seller? You might just have to RMA the drive and get a new one.
Just don't wait too long because if I remember correctly OEM versions usually only have a 30 day warranty.
Hope you get it figured out.
HatzLoves the funeral of hearts..... -
The memorex dvd+r I tried is also bought from office depot (B1G1F deal), but it doesn't work for me.Originally Posted by dazz87
Pioneer DVR-530H:Cannot burn to DVD-Rs, works with DVD-RWs
By boba_dk in forum DVD & Blu-ray RecordersReplies: 33Last Post: 31st Jul 2015, 13:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Pioneer DVR-112D connects but won't burn
By JessW in forum DVD & Blu-ray WritersReplies: 19Last Post: 1st Jul 2008, 00:41 -
Does Pioneer DVR-112D burn DVD+R and DVD+R DL media well?
By palmtree in forum DVD & Blu-ray WritersReplies: 26Last Post: 4th Jan 2008, 04:22
